desolder cables from psu
Cyberboy109
I want to remove pci cables from my cooler master psu since there not needed and I want a really clean look for a project im doing.
is this a easy job? any thing i should look out for?
I work on custom motorbikes so i know my way around a soldering iron.
It's not terribly easy, no. Basically on most PSUs the cables are soldered with a dozen or so others all in one solder pool. They are not separately soldered if that makes any sense.
As such what I usually do is open up the PSU and snip them about 1" from the PCB and then put a couple of layers of shrink over the ends of the cut wires. If you get shrink with glue in you can heat it with a heat gun, pinch it shut and then bend it over and press. It stays in position, capping off the wire.
Also, sometimes getting the PCB out can be a nightmare. It can sometimes be split into two or three PCBs that connect very tightly with glued connectors. There are also ground wires etc you need to remove before you can get the PCB itself out (and the power connector on the back).
I would just snip and shrink man, far far easier.
Very dangerous working inside PSUs (even with the power off) if you are not an expert.
Indeed. I recall a kid a few years ago dying from electrocution by disassembling a PSU that had a charge in its capacitors still, even though it had been unplugged.
Heck I even did it many years ago trying to fix a broken fan, not knowing the dangers of doing something like that. Not ever going to do that again lol.
Ye, messing about inside a psu is just asking tobe in a looney tunes cartoon, your playing russain roulete. And even though some in this thread have the skill, i think its wholly stupid to even put advice on how todo it as this is not something that a random diy person should try.
Just buy a modular psu.
Some of us happen to be PC modders, not gentle little flowers blowing gently in the wind.
Some of us might be, some of us dont want people to mess about with screwdrivers and soldering irons next to capacitors that could light there balls up like an xmas tree and kill them. :eek:
Oh for god's sake.
Find me one true instant with documented proof that some one was seriously injured by a PC power supply.
No, that's not a documented case of some one taking apart a power supply and being killed. That's a kid taking apart a PC that was unplugged and being killed.
Also you should maybe have read on before posting it? You'd have seen this bit.
It's not known what exactly happened. We simply know that the boy's father arrived at home to find his child dead.
OK, so no one has a clue what actually happened. They just came home and found their child dead. OK so from an expert, let me teach you something about capacitors. The charge they hold will be instantly released if you happen to short them. However, in order to do that you would have to be completely stupid, knowing nothing at all about capacitors. However, people do not die from just being zapped by a capacitor. It really doesn't work like that.
Can they give you a shock? yes they can, totally. Is it enough to kill you? I have never seen any one killed getting zapped by a capacitor. Ever. And I have seen people take massive whacks from the back of a CRT monitor tube. I myself have been zapped a few times when being careless.
Look on the bottom shelf at the 2000w amp. The one with the plexiglass lid.
It had caps the size of baked bean cans. I had just repaired it (two faulty volume controls and a broken trace on the back of the PCB ) and had a mate over who was sitting across the room from me in an armchair. I was pointing at parts of it and looking at him telling him what I had done when I put my finger in too far and bridged the capacitor. It sent me flying across the room. Well, first it felt like some one grabbed my shoulder really hard, then I went flying across the room.
Because that is what power is designed to do now. Send you flying. It does not stick you like a magnet and cook you like it does in those cheesy 80s movies.
Given that the amplifier I was running had absolutely enormous capacitors and didn't kill me? I think you would be reasonably safe inside a PSU.
However, if there was something wrong with you like a heart defect? then yeah, there's a very slim possibility that you could die if you received a zap.
Seriously, you are over reacting. If we all thought like that we wouldn't do anything.
I said that it was doable but not easy. Common sense should then prevail, and your instinct should advise you of your knowledge of electronics and guide you into making a sensible decision.
If you are that scared of capacitors simply stick the metal side of a screwdriver across them. You get a lovely spark and they discharge, making them completely safe even for flowers.
Your an expert because you got thrown across a room and you have been zapped by crts, mm ok. I mean do educate me more.
Can we stay on topic please.
Shingara give it a rest, there are modders on here who have the know how, just accept it and move along.
As for OP, it'd be easier to buy a Modular PSU and far less risky than what you intend. However stick with what has been said regarding snip and sleeve, will save you loads of time and possible complications.
Find me a sparkie who has never been shocked. It's like asking for a plumber that's never been wet :eek:
FYI? you can easily drain a PSUs caps before you take it apart. Just pull the power from the wall and press the power button a few times. Any remaining power will try and fire up the rig.
It's the same when you work on a car's electrics. Disconnect the battery, keep pressing the brake pedal.
