sheroo
Yeah that looks alot closer to the mark.
What speed is the Q6600 running at?
Stock atm. When this WU has finished I'm going to try and install Ubuntu onto a USB stick, and try and get that working.
I'd say thats pretty good PPD then. Although the WU's points are a bit all over the place at the moment.
When the points were a bit more stable and I had my Q6600 running at 3.4ghz I was just a hair off 10k PPD. This was running under Windows and no GPU folding along side.
That sounds pretty good. I thought a Q6600 produced a lot less than that. OK this is a real noob question - the "Credit" for the WU says 585 points, so how does that correspond to 5k PPD that FahMon is showing?
Also, anyone that knows, what kind of points increase can be expected from folding under Linux?
I'm running Linux (Ubuntu 10.10, fastest for Folding, imo) from a USB stick. Works fine.![]()
So you've got no other drive in the rig at all, and are just using a USB2 stick to load & run Ubuntu? Does the version of Ubuntu matter - what about 11.10?
EDIT:
What size USB stick do you recommend?
Yup, just a 16GB USB.![]()
And as Riot said, use EXT3 instead of the defaul EXT4 as it seems to function better.
I'm using 10.10 as it has the Intel specific multi threaded kernels available and it seems to give a nice boost to PPD.![]()
I used this as a basis of my install.. http://hardforum.com/showthread.php?t=1601608
Yeh that is right. How long did those 585 points take to complete? You will get those 5549.26 points in a 24 hour period (I'm pretty sure).
OK guys help me out here please, noob question alert.![]()
According to this image there is 5549.26 PPD & Credit 585 points.
Now after I completed the WU, my stats are only showing 585 points - is this right? Or am I being too impatient & the stats need to take longer to filter through?
TIA.![]()
You need to complete 10 SMP units with a valid passkey before you start getting the bonus points. A pain I know. Just need to power through those first few.
Sorry dude, don't understand. Are you saying that I only earned 585 points for 13 hours folding?
Basicly, yeah.
Once you have returned 10 work units and as long as your completion ratio is 80% or higher you will start to get the bonus points, which is when you will actully get your bonus points.
If you have a GPU you can fold with they also count towards your 10, which will get you your bonus points quicker.
OK guys if I press my desktop 2500K into service with the windows desktop client, what should I put in the client parameters in the advanced tab?
Thanks.![]()
