Dedicated Folding Rig
Pickster
I have been tossing around the idea of putting together a dedicated folding rig.
Today it came to my attention than 771 Dualcore Xeons are pretty cheap on ebay.
I have no experience with these. Will the motherboard be totally unable to overclock these cpus.
The idea being I can get the system up and running fairly cheaply and then expand out to two Quad cores at a later date.
This isn't set in stone just one of many ideas. So if it needs shooting down, go ahead. I'm open to ideas.
If you can find a Gigabyte X58A-UD3R with an i7-950 and oc it to 4.0-4.2ghz,6gb 1600mhz ram,and install it with ubuntu linux.Worth some 35k ppd.
Thats going to cost way more than I can out lay at the moment.
I know for sure I can get two 2.0ghx 771 Xeons for £30, motherboard +/- £70 and then a bit of Ram ontop of that.
Don't want to start a new thread,
but where the PIEP are those real BIGadv WU's ??
you know those that take at least 2/3 days ? and worth 300000 +- PPD...
Greetings Ray........
The points got adjusted, unless you mean the bigbeta ones that require 12 (or is it 16) threads.
OK, I am seriously considering the dual Xeon 771 setup.
Can anyone tell me if you have to use ECC ram in a 771 motherboard or if its optional.
I'm aiming for a board with atleast one 16x PCI-E slot (size) so GPU folding can be added at a later date.
I know this isn't going to be the fastest folding rig in the world, but for the price it's alright... Plus it has the 'Dual Xeon' cool factor
Edit:
Hmmm, I could get a fully working Dual 5130 Xeon machine deliverd for £150. So, soooooo tempted :s
Edit 2:
I have sent the guy (on ebay) an email. If I can get the price down a notch I'm going for it. Then later on I will drop dual quads in there
Bigbeta units as pickster said. They are still around, that's all I've been getting on my SR-2.
So, there is no shifting on the price...
To be fair £130 + £15 p&p is a fair price for a fully working dual xeon 2ghz workstation.
So, very tempted.
Then the 460 could go in there and I would have space for a 560 (Ti or not) in my main rig, once a decent deal rolls around.
hmmmmmm
So, very tempted.
hmmmmmm
Keep in mind you won't be able to overclock any Xeon setup (at least not very much) unless you go with the SR-2 and socket 1366 Xeons. With that said, if you get it for cheap enough then it's probably worth it, especially if you get an 8 core/16 thread setup that can keep running bigadv units.
It's just a 771 with Two dualcore xeons. In the future I will stick in two quadcores.
I have been looking at doing a cheap folding rig. It started with the fact I can get my hands on a 165 opteron for nothing.
Then I moved onto the idea of putting together a cheap 775 cpu/mobo combo.
However, I don't have any DD2 so I would have to buy that. Even cheap E6300 go for between £10 and £15, add the price of a half decent motherboard £50, then some DDR2 £20. All of a sudden a £130 fully working dual xeon workstation (hdd, dvd rom, 4gb ram) doesn't seem that expencive.
Edit:
If I can get a couple of the lower FSB xeons to drop in (which seems doable) I can always Pin Mod them for an overclock. But the ones that come with the workstation that I am looking at are already at 1333.
