Decent fans for radiator.
Terrifictez85
I have been buying parts bit by bit for my build. Bought myself an Enermax Liqtech 240 and the fans that come bundled are deafening. Could somebody recommend some quiet 120mm fans that would be suitable. My build is around Crosshair V so colour scheme is Black/Red (like every other build).
Thanks in advance.
So you'd suggest these?
http://www.scan.co.uk/products/120m...-white-led-high-static-pressure-fan-dual-pack
If so I can buy them with my 390 on Friday.
Oh yes! Those or the plain ones with the coloured accent rings.
These ones if you ask me (I'd personally go with PWM, that is what I use on my H100i and they are dead quiet):
3 pin: http://www.scan.co.uk/products/120m...pressure-1450rpm-3785cfm-23db-3-pin-twin-pack
4 pin/PWM: http://www.scan.co.uk/products/120m...tatic-pressure-fan-1450rpm-3785cfm-23db-4-pin
Just seen this http://www.cclonline.com/product/13...-Glacier-Pro-Series-12cm-Red-DBB-Fan/CLR0723/
68.5cfm at 15.8 DBA would this be any good?
Not sure about the price though lol was £131 now £4.48
Since I've personally never used them nor seen any reviews of them I can't really comment on them.
But from just look at them, they don't look like radiator fans. As they have many smaller blades, which looks to me that it's is more designed for airflow (intake fans) rather than static pressure (radiator fans).
As mentioned above, I'd personally go for the Corsair SP120's Quiet Editions PWM, which I have myself :)
