All done
Sweet miror finish on the CPU block:
CPU block installed:
Rad installed:
Pump installed:
Res installed:
Cut out one of the Expansion slot brackets to fit the 1/2" tubing and lined it with electrical tape... don't wanna cut the tubing:
Loop installed:
Filled it with water, unfourtunately there was a leak at the back of the rad. Turns out one of the Barbs was damaged:
Went out and bought new Brass barbs, installed and sealed. No more leaks:
Here's the finished setup:
And a shot of the light going through the Window. I sanded down the Window for a sweet glow effect, learnt that from Kempez
I innitially posted that over at BFG's forums:
Rad installed:
Pump installed:
Res installed:
Loop installed:
