I have a D5 pump, which I can set manually, but that isn't idea due to the fact that I would have to open up my case every time I need to adjust the flow.
It seems the manufacturer thought of this issue and supplied a connection for a motherboard PWM fan header.
So, I had my D5 plugged into the "CPU-OPT" fan header, but when I use Fan Expert II (ASUS P8Z77-V), it won't let me adjust the speed; it just shows it at max power and 4017rpm!
I moved the fan connector to "case-1," which would be the front fan, and I get the same result.
Any ideas on why this is happening?
Thanks.
Thanks.
