Customize laptop appearance
Rastalovich
I know there's a place somewhere but I can't remember where I've seen it.
Many laptops look dull from the outside, one grey color - looking for even something as simple as a set of stickers. Tacky or stylish ones, just to have a look at them.
I've heard of cases u can snap ur laptop into. Heavy duty protective ones for traveling and so on.
EDIT: Start the ball rolling, and a bit over the top for my liking : http://www.schtickers.com/
EDIT2: hmm customizable too : http://www.lapjacks.com/
I like the schtickers one as you can upload (I think!) you own images.
If you can upload you own images, then I can make you a funky design on teh Photoshop :p.
Hmmm custom outside sticker sounds like a plan. I'd love to somehow customize the inside of my laptop (around screen and keyboard) because it looks quite cheap with its silver plastic.
Both the UK and US sites above to an upload-customize thing.
Think I'll check the UK one out soon. It's about £20 I think ?!?!
(HP plain dark grey is a bit sucky)
You want a design?
Gimme your length and width of your outer "shell"/chassis.
