Custom Power Switch
RadeonHDx
I was just wondering how this would be done. I was hoping to use a button like the ones you can get from specialtech. If anybody could send me a link to how this would be done and if you could use a pictur it would really help.
Thanks! :)
Not too sure what you want us to say?
All power buttons are are push to connect buttons - ie, when you push it, it connects the circuit.
You just need to connect the wires from the motherboard terminal to the switch, doesn't matter which way round they go, and find somewhere to mount it and it will work.
this i had a vandal switch on my old case ill try and find the pics but basically all i had to do was cut the original case switch wires then i soldiered them onto the switch.
the switch i had also had +/- engraved on both sides so like james said it doesn't matter which way round they go its just a black and then red wire :D
well the website that used to host my old pictures is no longer there the owner sold it now its a different name i wish i kept the orriginals :'(
thanks guys, i would have put more effort into the post but I'm on my tablet so its abit harder to do links etc.
Thanks again for the replys! :)
