Hi,
For my next build, I want to use the Fractal R3 in White however, I want the inside to be matt black.
Without having to buy one white and one black case, which is the best way to go....?
When Tom created the Bengal rig for example, anyone know if the rig was sprayed using rattle cans... or even how to achieve the matt black finish?
The outer of the rig I'm thinking of covering in White carbon effect vinyl... some may say just buy the black case then. Still undecided on the carbon so would rather buy white.
Also, anyone know the best way to cut a window into the R3, or a compnay that could do it/supply the side panel cut?
Cheers,
Martin
Cheers,
Martin
