Look at Lutro0 customs youtube channel. Its not hard at all for the heat-shrink-less method. If you can put together a PC you can sleeve cables. My first couple of times I just sleeved the cables that came from the power supply. Now I can make my own at any length. The minimum tools you will need are a molex atx pin extractor and some wire cutters to cut the sleeving. Also you need some heatshrink and a lighter and thats it.
The first time I recommend doing one wire at a time. Take it out of the connector on both ends of the modular cable and sleeve it and put it back in. Also write down the pin-out as you take the cable out. Also if you have a Power supply that has more than one wire going to a pin, be careful and make sure you get everything back the way it came
Mike at Lutro0 customs has transitioned his site to join up with the folks at ModBunker. The materials and tutorial videos are at http://modbunker.com/
made me mind up i will do what tom said. i am going to get the corsair power cables for now but when i have ready to do my full case modding i will do then my self but thanks for the help everyone
do you have to get the ok for one to do a case mod i do not want to get in trouble if i do
