anthony eastwood
Strange things are a foot! my Mach 11 GT has been working fine for 5 months now, but over the last month my evaporator temps have been climbing it used to be around -54 -59 ish but its started going up and up its currently reading -91 on the blue LCD, I just cant come up with a decent explanation for this, all of this is under normal load, hit the O/C and they return to the -50 range, a week ago I did a hard disk relocation and noticed a slight weeping from one of the screw holes, thinking now is the time kill two birds with one stone I decided to remove the evaporator head firstly to solve the weeping screw head and secondly to check the state of the CPU socket and the surrounding area, surprisingly it looked the same as the day I had assembled the thing,,, clean as a fresh nappy. Having cleaned the components up I reassembled with new seal string this solved the problem of the weeping but not the climbing temps, am puzzled so if anyone has any experience of this kind of problem id be interested how you solved it or not as the case might be Thax
