Cosmos 2 fan controller and Bitfenix Spectre Pro LED fans
gponcho
Hi All,
I currently replaced the CM fans in the Cosmos 2 case with Bitfenix Spectre Pro LED fans (white colour) still using the built in fan controller on the Cosmos 2 case. I noticed that the fans led would pulsate on low and medium settings however would stay on, on the high settings. Can you please tell me why this is occurring? Also Since CM does not have White LED fans (as far as I know you have only red and blue LED fans) I was wondering as to what type of fans can I use that would support the fan controller and the LED on/off switch since the Bitfenix fans do not have a male end on there led connector so that I can plug in the controllers on/off led switch.
Could someone recommend an LED fan that is quiet and will work with the built in controller
I have searched for this myself as I am going to be getting a cosmos II and can safely say i cannot find any lol i'm guessing cm are releasing new fans in the future with the option
You'd probably realize our Hydra was pulled off of our product lists. We're working on it and something should be released soon so you can control your LED's and your fan speeds.
