Corsair individually Sleeved PSU Cable Kit, for AX 860
Gamepro105
HELLO!
Dose any one have any idea where the best and cheapest place to get myself a Corsair individually Sleeved PSU Cable Kit for my ax 860 is? i've been searching and there all expensive to the to point where i feel like i might as well braid them myself :P I want them in white :P
Thanks!!
Luke
Youll spend as much braiding them yourself + time to do it.
You have to buy the main kit + the 24 pin, the braid quality might be better if you do it yourself but the end finish and look will all be down to how much time and patience you have!
Im sure after trying to do your own you'd wish you bought the kit lol
I'll be getting a set soon myself ( in blue ) , the only place I've found them was from Corsair for $100 U.S. for the set.
Maybe after the first of the year I'll order.
seems I'm getting the AX860 to replace my AX850 under RMA. Been looking at them as well but yeah 100$ for cables seems a bit out of most pocket books. I have all the stuff to sleeve mine and now glad I havent since the 850's and 860's are different. I even went as far as to buy a second set of cables from an AX1200 to sleeve then found out they were not the same as the 850's so there still sitting in a box most likely headed to the rubbish bin as they dont sell well and are in a semi started state. lol
Haha, seems like we're going to have to sleeve our cables ourselves anyway, then. At least I can use a nice color pattern with the cables, white-blue for example ^_^
