It's not that BIG*reads comment*
lol...
*looks at sig*
DAT CASE!
*puts both comment and sig together*
LOL! OF course not! That M8 is massive.
As far as I can tell you, just from just looking at the pictures, you won't be able to put 60mm rad in the front of the case, especially if you using cards like 7970.There is just not enough room for that, I think that you will be ok with 30mm rad and 1 set of fans, but not 100% sure.I keep checking TTL youtube channel everydayhopefully there will be a review soon. I'm waiting for him to confirm about the front compability for thick rad like RX
It's not that BIG( they are bigger cases on market:lol: )
Yeah, to clear this for once and for all:
Top: 240 or 280mm radiator, with about 80mm clearance - spacing for 15mm-20mm.
Front: 240, 280, or 360 radiator, spacing dependent on GPU length, with room for fans in front of steel chassis for extra clearance.
e a way off yet, this was a paper launch.
Im sorry to say I own a 540 air and im so annoyed with it the widow panel is so cheep it marks so easy and not only that there was no 2.5ich cage in the back im so hacked off with corsair and how meny corners thay have done
Why don't you contact Corsair support over the missing part?
Post in the corsair forums here and greybeard will sort it for you![]()
