Corsair AXi Sleeves release??
Xayer
Does anyone know, when then sleeved cables for the AXi will be released?
I know that the sleeves for the AXi 1200 is already out but what about the rest of the AXi series?
Kind Regards,
Frederik
I forwarded the same question to Corsair and i got these links in return....
"Hi, here are the compatible cables and the compatibility chart
http://www.corsair.com/us/media/cms/manual/PSU_Sleeved_Compatibility_Matrix2.pdf
http://www.corsair.com/us/ax1200i-professional-individually-sleeved-modular-cables-red.html
http://www.corsair.com/us/ax1200i-professional-individually-sleeved-modular-cables-white.html
http://www.corsair.com/us/ax1200i-professional-individually-sleeved-modular-cables-black.html
http://www.corsair.com/us/ax1200i-professional-individually-sleeved-modular-cables-blue.html "
If im reading the Corsair*.pdf right, the set for the AX1200i, already on the market, will fit all "i" psu´s.
You can also see there are several new types of braided sleeve on the way for release in Q1/2013.
cables for ax1200i
try special tech or scan computers or isnt the ax1200i the same as the ax1200 i do belive that the only difference is you can use corsair link with the ax1200i the cables for them both should be the same but dont quote me as i could be wrong but ive got a ax1200 and when you look at them both they look the same but with a different label ie ax1200i ax1200
I like sleeve from moddiy site, but it's expensive... Srinkless sleeve is best...
People can order exactly color for some models of PSU like CORSAIR AX/HX series, Seasonic X series and Seasonic Platinum series. Set for Seasonic 1000 XP cost like new PSU.
That was not an answer to my question..
They have no dates for the lower kits yet.
If you cant wait buy the 1200 kit. Just means you have spare cables.
In my dialog with Corsair I just got the message that the kit for AXi 1200 was discontinued. New kits for the AXi series was under way but support had no release date to reveal..... Q1/2013.
Does anybody now where can I get the single sleeved blue cables for the AX1200i? it seems to be out of stock.. I just bought my PSU and I don´t want to void the 7 years warranty by sleeving the cables myself :S
Well STUNT....... - as mentioned in this thread the AX1200i sleeve-kit are discontinued.
New kits for the AXi series is on the way. No release-date yet.
Norwegian reseller Komplett.no told me they should have them in stock within the next week. So it should all depend on when your local shop /e-tailer place their orders with Corsair I guess.
Hefty pricetag tho :mellow:
80$+20$+shipping+toll+customs handling. Guess it would add up to a total ~160$ equivalent here in Norway. Thats just too damn pricey in my book.
