jamesriley94
Molex, Fan Controllers, Motherboard Headers: All fine options.
Some fan controllers.
i cant stand fan controllers for the fact that running wires back and forth (more sleeving) and
a cluster in the opti-bay to mention. i'd prefer trying to run the proper fan and if necessary use
a gang box or junction to tie them all together for the 12-volt, 7-volt and 5-volt power taps.
so instead in the viewing area in the front, place it behind the motherboard tray where it
cannot be seen. just my opinion.
airdeano
airdeano
T-Balancer/Big NG by Mcubed i am a fan and owner of a couple of them. i've tested and played
with them for a couple of years now. currently i'm testing the Corsair Link for the H-series and
fan/lighting control.
still i am not a devoted controller user. i prefer the molex under-volt.
airdeano
lollipop, i have the kit (CL-9011106-WW). i haven't played with the lighting side of the package.
airdeano
Yes. A 45mm thick 240 in the front, and a 30mm thick 360 in the roof.You got the Alphacool rads?![]()
Extensive Cabling Options
The fan’s short 20cm primary cable minimises cable clutter in typical applications while the supplied 30cm extension provides extended reach when necessary. Both cables are fully sleeved and a 4-pin y-cable allows to connect a second NF-F12 fan to the same PWM fan header for automatic control.
