Worst Kinda Duy
So I tore down my loop today to find out all my blocks had corrosion build up, the cpu block was the worst. My loop consists of Nickel plated copper cpu and gpu blocks, a D5 pump, a 2x140mm frontal copper rad, a 3x120mm upper rad, and chrome fittings.
I was on my phone while taking these pictures:
http://imgur.com/a/ZRQIi
I bought a new cpu block and thoroughly cleaned the water blocks. The gpu block in the picture is the worst of the three after cleaning. during Can anyone tell me if the blocks are safe to use? I replaced the cpu block with an all copper ek supremacy and switched my fluid form distilled water to EK nano fluid.
Long story short is all my stuff done? can I still use my blocks and rads or my pump?
Pre-cleaning pick of my pc:
http://imgur.com/Yo0SAar
specs:
I7 5930k
3x gtx 980 strix
specs:
I7 5930k
3x gtx 980 strix
