Cooler for a gtx660
athlon64
So i have a POV gtx660 and the cooler is not noiseless in idle. I have this one:
http://www.fudzilla.com/home/item/2...gt-gtx-660-ultra-charged-sli-reviewed?start=2
So i wanted to buy a better cooler. I don"t have much choice here in Croatia. I have an accelero extreme plus that i have to sell because it doesn"t fit and then i want to buy an other cooler. One guy is selling me arctic s1 rev2 with 2 scythe slip stream slims on it. The other guy is selling me artic s2 rev2 withouth fans but really cheap. I can also buy a new scythe setsugen but it"s a little expensive. Does the s2 and the s1 fit a gtx660 ? And will they cool well? Also does the new twin turbo fit a gtx660? I might be able to order it.
Also is the accelero mono good? It"s a bit expensive too. I could just buy 2 new fans for the stock cooler but i can"t plug them into gpu automatic fan controll.
I personally would buy better fans for it,
seems like that is very easy to do so mate , so yes that option would i choice :cool:
connecting is no problem !
and nice and cheap depending what fans you will choice....
Greetings, Ray.......
What do you mean by connecting is not a problem? I want then controlled by the gpu regulation. Not by the header on the mbo.
Sorry bit fuzzy, i meant soldering shouldn't be such a problem(?!) so you can connect it o to the GPU header..
Greetings, Ray....
Dude, i won"t be soldering on a brand new card that has 2 years of warranty.
I also don"t seem to be able to buy adapters in my country. I"m considering a accelero mono but it"s damn expensive.
Those stock fans will come off right,
then you have a connector you can use to solder, not on the PCB itself but just the connector mate , got me ?
maybe i am a bit fuzzy myself :wub:
