Boonstick
I've just added a second graphics card into my loop and I am wondering if my coolant is getting too hot.
Im running 2x 780Ti and a 4670K oc @ 4.6ghz.
I have 1x XSPC AX240 & 1x XSPC AX360 rad with fans in push.
My loop is pump -> cpu -> crosschill motherboard -> 240 rad -> gpu -> gpu -> 360 rad -> pump
Running Heaven benchmark my GPU's get up to around the 42C mark. Before it was about 34C. Ive adding in a coolant thermometer and on full load it reads about 38/39C. Should I be worried about this? Will I have to add more rad capacity? I knew it would get hotter but I'm just a bit concerned about the coolant temps...
Thanks in advanced!
Thanks in advanced!
