Hey everybody. It's been like 2 months since I used my computer and I noticed in the reservoir the coolant actually separated from the distilled water. Should that be a problem or is that perfectly fine??
Which one though specifically? Also did you make sure to clean the loop properly before filling? Did you dilute the coolant or add any extra additives?
