Hey, I'm making a cheapo computer for my friend. Basically, it is only for surfing the web and maybe some school projects. Tell me what you think of the build
Mobo: ABIT NF8-V PRO Socket 754 NVIDIA nForce3 250Gb ATX AMD Motherboard - Retail $69.00
http://www.newegg.com/Product/Product.asp?item=N82E16813127219
Antec Solution SLK2650-BQE Black Steel ATX Mid Tower Computer Case 350W Power Supply - Retail $75.00
http://www.newegg.com/Product/Product.asp?item=N82E16811129148
AMD Athlon 64 2800+ ClawHammer 800MHz FSB Socket 754 Processor Model ADA2800BOX - Retail $113.00
http://www.newegg.com/Product/Product.asp?item=N82E16819103485
Seagate Barracuda 7200.7 ST380011A 80GB 7200 RPM IDE Ultra ATA100 Hard Drive - OEM $56.50
http://www.newegg.com/Product/Product.asp?item=N82E16822148015
G.SKILL 512MB (2 x 256MB) 184-Pin DDR SDRAM DDR 400 (PC 3200) Unbuffered Dual Channel Kit System Memory Model F1-3200PHU2-512ZX - Retail $50.00
http://www.newegg.com/Product/Product.asp?item=N82E16820231011
3D Fuzion 3DFR4000P Geforce MX4000 128MB DDR PCI Video Card - Retail $49.50
http://www.newegg.com/Product/Product.asp?item=N82E16814143034
LITE-ON Black IDE Combo Drive Model SOHC-5236V BK RTL - Retail $27.00
http://www.newegg.com/Product/Product.asp?item=N82E16827106992
Just wanted to double check. Everything is compatible, and this build will do just fine right?
