Completing my build
Doomslayer
Hello all,
I would like to get some help, advice or tips on my build.
1. My current build - http://au.pcpartpicker.com/p/373zpg
2. Future build #1 - http://au.pcpartpicker.com/p/C9bnXL
3. Future build #2 - http://au.pcpartpicker.com/p/LKRv23
My plan is to removed anything that is blue in this system, I do have a budget no more than $800.00 AUD so that must include shipping I will only be using one shop which is PCCaseGear only, but if I can get into the $700.00 that would be better.
1. Cable kit: I will be buying the corsair metallic sleeved cable kit so in total will be $148.00
2. Water Cooling: Looking to buy a AIO water cooler in a 360mm i would like to get the Fractal Design one but it still hasn't come out yet so that leaves me with 1 choice does anyone have experience with the Thermaltake Water 3.0 units or would I be better of just looking at a 240mm or 280mm
3. Memory: I would like to put 16GB of memory in the system, I understand that games will not take advantage of it but I would like to have all of the ram slots fill.
4. SSD: I would like to get an SSD to replace my Seagate 1tb hdd i'm going to be using it for games and really only games that would take more advantage of modded games like skyrim & such, I have 5 ssd i'm looking at but they all seems to be about the same.
5. Fans: I'm looking at buying the corsair white led 140mm fans.
6. Video Card: I'm using the ASUS GTX780 atm do you guys think I should upgrade to like a GTX970 either a Gigabyte G1 gaming or the MSI GTX970 I do like the fact that the 900 series cards use less power than the high 700 series.
7. Fan Controllers: I'm looking at the Thermaltake Commander FX or the Phanteks PWM Fan Hub.
Your are more that happy to change the PC Part Picker list if you guys have better ideas.
Thank you all who are going to give me some advice or tips
