Am after a motherboard to complete my build....so far I have or its on order:
on order:
Lian Li PC-O11 Dynamic Black ATX Case, T/G Windows, $185.00
Noctua NA-SEC1 chromax.red 30cm 4Pin PWM Extension Cables
Noctua NA-SYC1 chromax.red 11cm 4Pin PWM Fan Splitter Cable (3 Pack)
Noctua 120mm NF-S12A PWM chromax.black.swap 1200RPM Fan (6 off )
Thermaltake Water 3.0 360 ARGB Sync Edition Liquid CPU Cooler
will be using this from current PC :
G_skill trident F4-3200C CL 16 1 18 38 ( 4 x 8G )
2080ti gpu
M.2 Samsung 970 EVO 1TB
2 Samsung 850 EVO 1tb SSDs
And its missing the Motherboard...have seen the Aorus Master review but am not sure as its expensive so maybe the Taichi motherboard. I do like the number of fan headers on the Master and the number of USB ports on the back of the case. Maybe the Hero from Asus but I am not a fan as they are very slow booting and also expensive.
So many cheaper ones are good but lack the Fan headers to reduce costs but the put HDMI on the backplate
EDIT: i SHOULD HAVE PUT A
IN THE HEADING
on order:
2080ti gpu
