COD4 1.5 patch
Brooksie
http://www.infinityward.com/modernwarfare/patch/
CHANGES:
* Fixed server browser not showing all of the servers
* The "hold [ ] to steady" sniper scope hint will only appear if you can use it
* Fixed game not recognizing IWDs existing if they are all in fs_basepath and none are in the main/ folder
* Made mod scripts able to change stats
* Allow developer_script for mulitiplayer modding
* Fixed map rotation errors with usermaps
* Fix for reloading several times after connecting to a modded server
* Fixed minimap not showing up in the menu for usermaps
* Fixed an issue with Http redirect downloads.
* Mod tools will now work with other languages
NOTE: patch 1.5 is not compatible with 1.4. You will not be able to find 1.4 servers if you update.
NOTE: Please ensure you have previously downloaded 1.4 patch before downloading 1.5 as you will need the 'Winter Crash' map from 1.4.
