CM690II advanced or an alternative
hokxj
So I'm going to be buying a computer within the next week and I'm having trouble deciding which case I want. My rig will include a 2500k with Hyper 212+ and a 6950. I will be overclocking to about 4-4.3ghz.
I'm considering the 690ii advanced with the window which is $121.50 AUD. I've heard that the 690ii has issues with stock cooling? I don't want to have to deck out the 690ii with fans if I could get a case which has good stock cooling already for a bit more.
Another thing to mention is that the computer will be in my room without aircon in summer where the room temperature easily gets to about 33 degrees celsius.
So my question is how many fans would I need to add to the 690ii for it to be decent during summer and overclocks. If this number exceeds 2, then what would be a decent alternative?
My requirements are:
1. I would buy from http://www.umart.com.au/pro/products_listnew.phtml?id=10&bid=5&id2=139
2. No Haf, antec 900, 902, or storm scout cases as i find them hideous.
3. My budget is $160 AUD so I think the most expensive one I'd go for is the raven 03
4. My motherboard doesn't have usb 3 headers, so if the case has usb3 I/O then it needs to have usb 3 passthrough cables
5. I dont care for watercooling
Thanks in advance!
If you have thought about the RV03,go for it
You wont get better aircooling
