M Munster New member Sep 16, 2014 #1 If i insert a h100i in push intake in the front, and I move the 3.5" drive bay to the left mounting holes. What would be the new maximum length for the PSU?
tinytomlogan The Guvnor Staff member Sep 16, 2014 #2 I dont think youll get a specific answer - but if you buy a PSU that doesnt fit the gap youve bought the wrong case to start with Most good PSU's will be 160 to 180mm long and that will fit fine
M Munster New member Sep 16, 2014 #3 I haven't yet bought the case or PSU. I know the HDD bay can move to the left slightly, but I wasn't sure what length that would leave for a PSU. Its either the Silencio 352 or the Corsair 350d. I'll be housing a h100i and a BR-rw in a mATX build.
