cisco 2960
evo-man
I been give a cisco 2960 switch and i am having trouble setting up lacp on it i manged to set up the rest of the feature on this switch which i need but the cisco documents and the you tube videos i have found are not helping. Is there any1 out there that has one of these switchs or cisco know-how to set the ports up right.
i am using a 4 port intel gig nic card which has the software and drivers for teaming set up and they work on my netgear pro safe gs724t. when i try and unplug them and put them into the cisco switch i am unable to set the command line up to accept the config. i am using putty and concole port to get access to my switch any help will be great
I can do Cicso! How far along are you? Have you not got the commands in or are they in and just not working?
Post the output of 'show run' here and I'll take a look. Look through it before you post to remove any passwords etc.
