23RO_UK
Firstly, why the name Chunk?
When the Nano arrived and I unpacked it, I received the comment “OMG, it’s a chunky little thing isn’t it…” Normally I'm not one for pet names for PC's but the name has kinda stuck ever since
Moving on, it has become readily apparent since I revamped my Meshify Compact rig that a second PC was needed, as a home workstation principally, general household use and legacy gaming (there are a fair few games I still play that require a workaround to work on 12th Gen Intel CPU’s in the here and now, some titles just won’t work period unfortunately).
The brief, I wanted to reutilise as much existing hardware as possible to keep down the cost, this meant finding a case that would accommodate an ATX power supply, my Noctua NH-D15S chromax.black cooler, that it be high airflow and have a small footprint as ideally I intended to use an ITX motherboard; ultimately Fractal’s Torrent Nano Ticked all the boxes.
First up the new kit -
And now from the collection of existing kit -
(Yes, I know what you're thinking, let’s just say I still have more unused kit kicking about and yes, I really should think about getting rid of some of it lol).
So, build wise, it was an absolute pleasure to work with, cable routing was an absolute breeze as there is a ton of room behind the motherboard tray; the one exception being you need to remember to attach the EPS cable prior to installing the motherboard, you'll also need to route this under the PSU before installing it.
In terms of the build quality of the case, it’s a Fractal, say no more, in short, I absolutely love it.
- Fractal Design Torrent Nano Black Case
- WD_BLACK SN770 1TB M.2 2280 PCIe Gen4 NVMe (to use as an OS drive)
- AMD Ryzen 7 5800X CPU
- Noctua NH-D15S chromax.black CPU cooler
- Gigabyte AMD B550 AORUS PRO AX Mini-ITX Motherboard
- ZOTAC GAMING GeForce RTX 3070 AMP Holo GPU
- Patriot Viper Steel 32Gb (2x16Gb) DDR4 PC4-28800C18 3600MHz Dual Channel Kit (PVS432G360C8K)
- Samsung 970 EVO PLUS 500GB M.2 2280 PCIe NVMe
- Two Crucial MX500 1TB 2.5" SATA SSD’s
- Fractal Design ION+ 2 80+ PLATINUM 860 Watt PSU
- A Noctua NF-A12x25 PWM chromax fan (mounted as an exhaust)
