Hey guys,
Well to start, I have to stay around my grandparents a lot of the time (lol
) and y'know, you get a bit bored from time-to-time, so you game in these situations (if there's nothing else to do, and/or your grandparents are a bit silly as being over-protective and you can't really go out).
So my grandparents current comp (which I built) consists of the following:
AMD Athlon 64 X2 6000+ (@ Stock 3.0GHz)
2X1GB Crucial DDR2-800MHZ CAS5 RAM.
XFX 4550 512MB GDDR2 Fansink stock 625/500 OC'd to 650/550
ASUS M3A76-CM Motherboard (BIOS 2101 / Latest)
The resolution of the monitor [which I also gave them, lol] is 1280x1024
Even at the lowest game settings (aside from the res. being native) with the GPU OC'd, framerates will be beyond dramatically poor.
There are forum threads out there discussing the best GPU for the 6000, although they have never come to a conclusion. I am planning to go ATi for this rig anyway, best price wins, and I'm finicky about keeping everything one branded. xD
Now, VRAM isn't much of an issue at this resolution, and 512MB GDDR5 should do it (if I go for something in the 5K series). Arvutihull on YouTube told me that a 5670 would be the best match.
I don't want ANY power of the GPU wasted. I feel that if I spend 'wasted' money, that it's pointless, especially in the situation of trying to get the best price.
What would be the best choice?
And if I were to run some Anti-Aliasing; say... MW2 maxed at 1280x1024 with 4xAA, would 512MB still cut it, or would I need the higher VRAM buffer to use AA at this res with high game settings?
I'd also be looking for 60FPS+ on games like that. Some games such as Crysis are an exception. BTW, does the original Crysis have a key 'limit' (Not referring to Warhead with it's revoke tool)? I've heard yes and no. Would like to know that as well.
Hope you guys can help me ASAP.
Thanks
Thanks
