Cheapest crossfire setup
stevej696
Hi
I was jus wondering my brother wants a cheap crossfire system for around £300 which he needs to buy a cpu, mainboard and 2 gpus with. Weve put £120 on the side for the gpus but which is the best for crossfire setup? Ive looked at the 5670 512 ddr5 setup which comes in at £115 but is there any other setups that is better?
He wants it to play COD, Far cry and Dirt at 1650 x 1050 resolution if possible but I can lower the res if performance will improve
On a last note it has to be crossfire not Nvidia SLI and no single card! Brothers orders
Thanks in advance
For some reason he wants crossfire. He has friends who have a crossfire setup so maybe that has something to do with it.
For a budget setup, you don't go crossfire really, unless it was BOGOF, which I sincerely doubt bearing in mind this is computer hardware.
If his budget is £120 for the cards, you wont find many decent and reliable cards for that price - decent cards cost that amount upwards for 1.
With that as his budget, id recommend a single overclocked 460 which will wizz all over his mates set ups if they have similar priced systems
Ok so talked with my bro and he finally agrees with the single card setup on the condition that its a decent one! So were going with the 6870 on a crossfire ready motherbaord for the future if he wants it.
So the specs we have so far are:
Gigabyte GA-870A-UD3
8GB of Mushkin blackline DDR3 1600MHZ
Cpu- Still deciding but maybe a phenom x3
Gfx: ATI 6870
As a footnote i was thinking 8gb of memory but could i save the £36 and just use 4GB? Shud it be enough?
Im asking because my bro's starting college september doing 3d modelling and design and would eventually need a pc that can use photoshop etc. Future proof while prices are cheap??
Cheers guys
Gfx: ATI 6870
Cheers guys
dont get a triple core
Since Bulldozer is likely to come out June/July (if the rumours are fair), could I convince you wait for BD to push down the prices of AM3... then consider if you're going for 870 chipset to have a look at the MSI 870A Fuzion Power Edition. That thing overclocks like a biatch, let's just call it AMD's Sabertooth.
I'm not familar with graphics rendering to comment on hardware focus requirements; which to prioritise among RAM, GPU, CPU clock or cores.
That's the board I was originally going to get if I went with AMD, but then I saw the Crosshair and nearly cried with joy. So I decided to go with Sabertooth P67 because I knew if I went AMD I'd end up spending more then I could afford, just on the MB and chipset
Thats an awesome board I actually forgot that it was reviewed here! (Sorry Tom
) This is looking like the perfect motherboard to be honest.
Ohhh the possibilities!
Ati + dedicated Physics = monster
Looking at the price its going to be not too bad as i was now thinking a 5830 radeon + gts 240 for physics, 4gb mushkin ram, phenom x2 black edition overclocked all running on a MSI 870A Fuzion Power Edition
Total cost around the £350 mark with delivery. What you guys think better than origional thoughts??
