Changing fan speed on a BFG GeForce 7900 GT
InsanePyro
I have tried every possible program I can think of to increase my fan speed. And with every program the option is either greyed out or missing completely. Any ideas?
And the card is new enough as I was able to do it with my 6800 Ultra
Any ideas would be great!
You sure it's not locked to auto in the control panel or the software you're using?
On some things you have to manually unlock the manual fan control before you can play around with things.
No idea where you'd find this setting though
I contacted nVidia and they said BFG may have locked it down but I don't see why they would
I'd expect one of the weirder brands to do that not one of the better ones
Yup...I can't believe they would lock down the fan speed but still allow me to overclock it (yes I can play around with the clock speeds just fine)
By the way this is the stuff I'm dealing with. Models will randomly bug out like that. The weird thing is the game itself still runs smooth it just has all these weird model glitches all over the place. I kept track and the hottest the gpu got was 70C right on the dot and I've heard thats just the start of actually overheating
