Case recommendation
SolarNova
Greetings.
So i have gone through 6 NZXT Phantom 820 White editions. Each of them have had paint issues, mainly chipping. Im now looking for somthing different.
I like the phantoms slick smooth looks, so somthing simular would be nice.
White is the color im after also.
A bonus would be a 90 degree motherboard mount, with the I/O at the top of the case, like the Silverstone casses.
Anyway if any1 has any sugestion please do speak up, the issues with the NZXT case has caused a birthday build for a fmaily member to be delayed now so i want to get the case ASAP.
Cheers
If you're looking for white full towers with curves:
- CM Storm Stryker
- Corsair 600t White (Large mid tower)
- CM 690 II Black & White
- Bitfenix Colossus White
You could also have a look at the Aerocool XPredator range, but reading your OP I think you're after good quality products. Aerocool is not really a brand where you can find those.
If you want to try another Phantom case, there are also the Phantom 410, Phantom 630 and the new Phantom 530.
NZXT likely use the same white paint on al their casses so i wont be getting a NZXT case dispite how much i like their looks. The paint is just sooo weak.
ATM the only 2 cases im even considering is the Corsair 600t white and CM Storm Stryker White.
I would prefer to have more options though.
