Case options ATX
RobM
Active member
Need some ideas on cases please for a Ryzen 5 build
Must be able to house an ATX board in other words this needs to be a standard ATX build but in not so tall space.
Max Height :400mm
Max Width: 330mm
Max Depth: 480mm
CaseKing spat out only Lian Li PC-A05FNB with those parameters. Have you purchased the board? If not why not go mATX or ITX? There are many cases that fit those dimensions for smaller format boards.
Its a new build for a friend with Prime x470 Pro, has the features needed with a good VRM
Yeah with the Gene boards from ASUS you can get some nice performance in the mATX form factor?
