Hi guys,
after much holding back i have decided to let the wild side come out to play and have started to mod my own case
. I plan to cut new fan holes, windows etc but im stuck on what cutting disks are needed to cut thru 0.6 to 1.2mm alu?
I'm gunna be using a dremel to do the cutting on an old case first to get some practice and need the disks. Does anyone know where i can find cheap disks that will do the job?
Cheers
stevej696
c3d:
Cheers
stevej696
