and now you have no boot hahahahaha :huh:Just get a cheap 2nd hand sub you wont notice any audio difference between a cheap sub and an expensive one in a car, and if you mess up the wiring and it pops it isn't as painful for your wallet.
This is my brothers it cost him £40 and it shakes the house.
I'd agree if I just hadn't spent the day struggling with bootspace.Who needs a boot at 18 :lol:
trust me you will need it at some pointWho needs a boot at 18 :lol:
Corsa sound systems are so crap you do need to go all retro and 2000-esque. Unless you want to go for the old school 1990s phone speaker sound quality.good luck transporting bodies in that boot. i tested my old scirocco. you could get a 6ft man easy with room for a average height female aswell. this was a mistake. also. sound systems are soooooo 2000s.
just love those cars!! aaah if i ever have to money to buy one i instantly will, been my dreamcar since i've been a kid ^^
We installed a full Sony Xplod system in my mates Sierra, including:
8x drive speakers (Dash & Doors),
4x tweeters (Dash & headlining),
2x parcel shelf 6x9s, 2x 16" Subs,
2x 1000w Amps,
1x Power cap,
1x Leisure Battery,
Xplod Head unit
and 16 Meters of Brown bread sound proofing.
1x 8'x4' 18mm MDF (Bass box)
20 Meters of Black Felt Carpet.
If you put the time and effort in you get amazing sound quality.. Of cause it all costs a small fortune and lots of fun wiring it all in.
If you could make a guide that would be great, kthanx.
:lol:
Speaking of car audio, I've always wanted to upgrade but don't have the knowledge or tools. I follow Steve Meade on YouTube though, wish I had his workshop!
Really???
Ever heard a high end car audio system, there is a massive difference between the cheap stuff and good stuff!
Its like comparing the Z87 to B85!
I've had cheap, fli, mutant and other halfords shit stuff, ive also had Audison, Rockford Fosgate and JL Audio stuff and i will ALWAYS buy the better stuff, audio is alot more precise, crisp, more pleasant to listen to.
Just because it shakes the house doesnt make it good as the expensive option, in fact thats the complete opposite!
Im not saying don't buy cheaper stuff, sometimes you have no choice, but before making such bold claims do some research.
Well I've had a hellish few weeks with my car :/. new radiator a few weeks ago due to overheating, didn't work. Fan wasn't cutting in so we replaced the sensors for water temp etc. Still didn't work so we tried a new thermostat, as the fan worked when we wired it to the battery. Whilst bleeding the air out of the system a bolt head broke off and it started throwing coolant everywhere -.-. Took the thermostat housing off and got the bolt out then took it to a parts shop and got a bolt for it.
Fan still wouldn't cut in so we took a closer look at the fan, turns out in Peugeot's infinite wisdom that the fan resistor should go at the front, bottom of the car where all the salt and water can get to it. Summed up, it was mostly blue with corrosion. Bypassed it by joining the wires and now the fan cuts in at 85 degrees without fail. Takes a bit longer to warm up now and doesn't get to the normal running temp it used to but at least it isn't overheating :L.
