SkinToxicated
Hey guys, Im the proud owner of a 4770k and im cooling it with a H105.
Its stable a 4.4 @1.25volts (i tried turning it down to 1.2volts but is failed), but when i put it 4.5, at every voltage increment up to and inc 1.29 (i know not to go higher) it crashes
here are screenshots of my bios and occt stress test after 30mins @4.4Ghz @1.25volts
so that's what I'm doing and as you can see, temps etc all with reason. now the more keen eyed of you will notice the occt and cpuz are showing the CPU @.856 volts. when TTL reviewed this board (well the G65) he said that its a bios issue about voltage displays and as you can see from the bios pic im at 1.25 volts
So my question is am i doing anything (majorly) wrong here? is 4.4 on water is respectable and i have been deluded by all this vids of other peeps getting 4.5 on air/4.7-4.8 on water just getting cherry picked examples and ive just had some bad luck in the silicon lottery?
Cheerz in advance guys
