Hello All
My Canon IP4200 Inkjet Printer is getting low on ink so I was looking round for cheap cartridges to replace the current ones when they finally run out. I have found that you can now buy compatable ones at around £6.99 for 5 but you have to take the chip off the current cartidges and put them on the new ones. Has anyone used these or had any expierence with taking chips off one cartridge and sticking them onto another and is it really that easy. Since a full set of canon ones will cost £45 then I guess if its that easy then its worth it ?
Any help is very welcome.
Thanks.
Thanks.
