Can someone please help me out with what the best fan setup is?
sebastian869
Basically I have an ARC Midi R2 and an Asrock extreme6 MOBO. It came with its own self control 5-7-12v fan controller. I'm looking for a setup that is more controlled by the needs of the hardware. I no longer have any free 5.25. I was thinking of getting 2 140mm in the front one 120mm on the floor and one 140mm in the rear high air flow to kick the air out. (Am currently running corsair h100i CPU cooler and its normally point in I would change the air flow out of the case) Was thinking of using something like a:
http://www.swiftech.com/8-WayPWMsplitter-sata.aspx or http://www.corsair.com/en-us/corsair-commander-mini
http://www.corsair.com/en-us/corsair-link-cooling-kit
. What do you guys think of this idea and which hardware would you select?
Thanks.
