Can anyone help me?
Danny123470
I am looking into upgrading my CPU cooler, the one I currently have is an Arctic Cooling Freezer 7 Pro Rev. 2 and I am looking to upgrade to a Be Quiet! Dark Rock Advanced. However, I have a CoolerMaster Elite 430, which is a mid-tower case, and I am just wondering if anyone has any idea if it would fit
Cheers guys,
Danny123470
A rule of thumb is that if a case has a 120mm fan on the rear then normally a tower cooler with a 120mm fan on it will fit.
Thanks for the extremely quick reply, I think I'm gonna go for it, and hopefully it will fit, it not, then I'll keep it until I get my Corsair 600t
I had a quick look at the specs of the case and the cooler, here they are
Case (CoolerMaster Elite 430): - 190mm Width x 424mm Height x 490mm Depth
Cooler (Be Quiet! Dark Rock Advanced): - 95mm Width x 167mm Height x 122mm Depth
Just in case anyone wanted a second check
As an aside the mounts for the Dark Rock Pro & Advanced are very fiddly & quite frustrating. If you intend to swap it out quite often then I wouldn't recommend it. However the recent review says it is whisper quiet.
It would probably just go in and stay in really, thanks for the extra info
Have a look at this review about 17 mins in & he explains how fiddly the mounting system is.
[media]http://www.youtube.com/user/TimeToLiveCustoms#p/u/60/k6YH_tuA5DU[/media]
The review is for the Dark Rock Pro but it uses the same mounting system as the Advanced.
Talking about tom as if he and the channel weren't part of OC3D
