My boss was about to call a guy to come and have a look at a broken fridge, but I have offered to have a look at it before he spends hundreds having it fixed.
Sorry, I know it’s not cooling a pc but if I can fix this, I feel a little bonus coming my way, witch ill spend on an xpot
The problem happened when the fridge was moved 6 months ago for cleaning. Somehow the rad and fan got bent towards the condenser but about 25 degrees, and was turned off strait away as I have been told. I straitened it back, and have cheeked for bent or broken pipe, all seems fine.
The fridge as you can see in the pics is on but, no spinning fan and no sound from the condenser. my guess is when the fan got jammed it blow an internal fuse, but before I go taking the thing apart I just wanted to see what you guys thought.
This is just the ambient out side temp.
Am i right in saying the is were the fuse is.
Im not Fgas Tested so i wont be messing the phase unit at work.
