FireCharge
Hey guys, currently own a Seasonic X850 PSU and using a custom 8+6 GPU cable from Cablemod (not extension).
Thing is I'm going to mod the psu shroud I made for my NZXT Phantom 410 soon and add a hole for the GPU cables, and the 8+6 doesn't really look that good.
So a couple things came in mind:
1. Can I somehow just cut the 6 pin add-on and keep the 8 pin? Is it safe?
2. If not (technically if so as well), should I pick up extensions or just sleeved cables? Frankly I'm leaning towards the extensions because the sleeved ones seem to have extra cables for some reason (I.E. several connectors leading to one specific connector, which is bugging me)
Thanks for the help!
