[Buildlog] Watercooled 900D
Man is that a tight fit...i need a bigger case :D
corners looking good.
but why the hell is there a hole in my 5.25" bay? :o
So i thought i could make a cover for the 5.25" bay. i never bend metal sheet...so i made a quick prototype :D
first bend, and it dosen't look to bad!
moar bending! i'm bender!
it kinda fits....if i take the time to do it right i should be able to make a nice cover
But why do i need a cover? Because my 5.25" bay has holes :D
And it fits a HDD cage!
MKII of the cover went really well, i took my time (4hours)
Now i have space for 3 secret HDDs !
Today i finally got my plexi for the lightbox!
File it into the right size and but some LEDs in between, easy!
I put this just for a quick look together, and sadly it's way to bright. I think i should get a less translucent plexi for the top.
but it works :D
i works is an understatement
it looks flipping amazing
:notworthy::notworthy::notworthy:
i'am absolutly no fan of the corsair 800d and 900d ( if it's not heavly modded )
i just dont like the standard inner layout
but this is going to be an absolute beauty of a 900d
hats off to you sir hats off
:rock::rock::rock:
moar i want moar :lol:
I bought a second plexi for the top part and cut the ledstrip to the right length. Now i can look at my lightbox without going blind :D
Move along, there is nothing to see here!
I didn't had to much time last week. I finished my hdd tray, had to cut a hole into my back cover
The HDD thingis were to long, so i had to cut the lever. Now it fits nicely!
And now disappear!
My lightbox didn't illuminate 100% even so i had to fix that too...First picture installed in the case!
I bought a Aquaero because it's the best fancontroller ever. I want to hide it somewhere in the case but i'm not sure where...i didn't know that the cheapest version comes with all the functionality, that's kinda nice.
I made a 4-way fan splitter for on of the radiators, i'm a bit rusty when it comes to sleeving but i think it turned out ok.
I made fanplitter cables for the rest of my fans, it seems like it's going to be really cramped in the bottom compartment. Even with all fans at 100% and no panels on the case it's really silent.
I also sleeved the front I/O connectors turned out really nice! I forgot how much time consuming sleeving is :D
The Tower of Cooling!
First of i have to thank the guys from Aquacomputer for their great support! They granted me a really nice discount for my build. Yay Aquacomputer, and speical thanks to Lukas Depre!
I'm really short on time these days, but it will go forward soon. Now i have to unpack all the nice shiny stuff :D
