[Build Log] ***** Snef's Anti-Venom*****
snef
great news
a new Client build
and believe me it will be a GREAT build with a lot of power
name is Anti Venom
I will do a regular build logs and video
specs:
Intel I7-6700k
GIGABYTE GA-Z170X-Gaming 7
2 x GIGABYTE GeForce GTX 980 Ti Windforce 3
G.SKILL Ripjaws V Series 16GB (2 x 8GB) 2800 DDR4
HyperX Predator 240G M.2 PCIe
SAMSUNG 850 EVO 1TB SSD
EVGA 220-GS-1050-V1 80 PLUS GOLD 1050W
Caselabs S8 white with top windows and front windows
Water cooling:
EK Supremacy EVO Nickel clean CSQ
2 x EK-FC980 GTX Ti WF3 - Nickel
2 x EK-FC980 GTX Ti WF3 Backplate - Black
1 x EK-FC Terminal DUAL Parallel 3-Slot - Plexi
13 x EK-Vardar F4-120ER (2200rpm) White
4 x EK-Vardar F4-120ER (2200rpm) Black
2 x Mayhems X1 UV Oil Black Concentrate - 250ml
2 x Bitspower Premium Magic-Cube Type DDC MOD TOP G1/4" (Acrylic Version)
2 x Dual / Single DDC Top Upgrade Kit 250 (Clear Acrylic Cap)
2 x Bitspower Water Tank Z-Multi 100 - Limited White Edition
2 x Pump Cooler For DDC/MCP355 (Deluxe White)
2 x EK-DDC Anti-Vibration Mounting
2 x Laing DDC 3.1 Quiet 10W Pump
1 x EK-CoolStream PE 240
2 x EK-CoolStream XE 360
2 x Feser One - Cooling Fluid - Pure RED
16 x Bitspower G1/4 Enhanced Multi-Link Adapter - 12mm OD Rigid Tube - Deluxe White
10 x Bitspower Premium G1/4" Deluxe White Stop Fitting
2 x Bitspower Ball Shutoff Mini-Valve - Deluxe White
2 x Darkside 14 mm Rotary Spacer Adapter - Male-Male G1/4 - White
2 x Darkside 3-Way G1/4 Flow Splitter - Clear
6 x Bitspower 90 Degree Rotary Adapter M/F G1/4 Gloss White
10 x Bitspower PETG Link Tube OD 12mm - Length 1000mm
Lightning and Cables
12" (30cm) DarkSide CONNECT Dimmable Rigid LED Strip - WHITE
Ensourced cable kit for EVGA power supply
This look interesting, it will be nice to see a decent build in the S8, with the same config I very nearly went for last month. ( well up up until another company going bankrupt, and me now being jobless again ) At least I can live vicariously through this build...
