SEBAR
I am using the Bitspower Water Tank Z-Multi Res 150.what res are you using Sebar?
Yes it is easy to mount. It you plan on mounting it to a 120 fan location you will need an adapter. I am using the Bitspower 120 Water Tank Mount Panel (RAD Side) - BP-120WTMP-BK that I got from Sidewinder Computers.I ordered one on saturday for CoolSair,
first time using a tube res,
was it easy to mount?
Should be no problem, you may have to drill a couple holes but other then that no worries. You will like this res, it is very nice. Be shure to leak check it good. I had one that had a pin hole leak in the three port cap. Bitspower replaced it no problem. I made a video explaining the leak. http://www.youtube.com/watch?v=-3yV6m0B-_Ylooking at mounting it onto the Mobo tray, roughly the same place where TTL has his, just behind the front rad
Thanks, it should should look a much tidier when I get done. In facty I already have the sleeved cables in and it looks stunning. I will try to get some updated pics today when I get home from work.Phwoar thats pretty tidy :drool:
Anytime, good luck on your build. From your build log it seems like it will be a beast of a system.cheers mate great help!
This is looking like an absolutely stunning build! Keep the updates rolling in, I would love to see the finished product soon![]()
I think it's much better than original.
C70 Gunmetal Black is nice case too.
I liked C70 in that color but old Obsidian class is my favorite.
Thanks, I tried a couple different variations.I like the new look of the motherboard SEBAR, it looks really awesome![]()
Here it is following the standard layout of the yellow accent.
Here is a modified version, this one is my favorite and I will be keeping the motherboard like this.
