GamerGirlAlice
im looking to build a budget gaming machine and would like some advice on it, below are some parts im looking at. im trying to figure if i should raid 2 corsair force 3 60gb drives or a single corsair force 3 120gb as a boot drive. ill be running windows 7 ultimate 64bit. also is the Intel Core i7-3820 Sandy Bridge-E 3.6GHz a good enough processor??? i live on a tight budget and building things a piece at a time. and my last question is would a corsair ax650 be good for a dual sli or crossfire or should i go ax 750. i already have a corsair 800d case, 22" samsung 3d monitor, and some 5.1 speakers i plan to reuse for the build. ty in advance.
MSI X79A-GD65 (8D)
CORSAIR Vengeance 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CML16GX3M4A1600C9B
LITE-ON 12X BD-R 2X BD-RE 16X DVD+R 12X DVD-RAM 8X BD-ROM 8MB Cache SATA Blu-ray Burner with 3D Playback iHBS212-08 LightScribe Support
Edit: i put together a build list so u all can see idea beter. its at http://secure.newegg.com/WishList/PublicWishDetail.aspx?WishListNumber=14715214
MSI X79A-GD65 (8D)
