budget build for mate
For the GPU if you are going AMD like AlienAX said go with sapphire, xfx and I heard the MSI card was okay too. Possibly the red devil version too.
That's a pretty good list dude, I have this so far myself.
PCPartPicker part list: https://uk.pcpartpicker.com/list/N8d9QV
Price breakdown by merchant: https://uk.pcpartpicker.com/list/N8d9QV/by_merchant/
CPU: AMD Ryzen 5 1400 3.2GHz Quad-Core Processor (£158.99 @ Amazon UK)
CPU Cooler: Cooler Master Hyper 212 LED 66.3 CFM Rifle Bearing CPU Cooler (£22.49 @ Ebuyer)
Motherboard: Asus PRIME B350-PLUS ATX AM4 Motherboard (£88.72 @ Amazon UK)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400 Memory (£111.19 @ Aria PC)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive (£41.90 @ Amazon UK)
Video Card: Gigabyte Radeon RX 570 4GB Gaming 4G Video Card (£164.99 @ Amazon UK)
Case: BitFenix Nova ATX Mid Tower Case (£28.86 @ Aria PC)
Power Supply: Corsair Builder 500W 80+ Bronze Certified ATX Power Supply (£49.80 @ Aria PC)
Operating System: Microsoft Windows 10 Home OEM 64-bit (£84.60 @ Aria PC)
Monitor: Samsung S22D300HY 21.5" 1920x1080 60Hz Monitor (£82.99 @ CCL Computers)
Keyboard: Logitech K270 Wireless Standard Keyboard (£17.40 @ Amazon UK)
Mouse: Logitech B100 Wired Optical Mouse (£8.99 @ Amazon UK)
Total: £860.92
Prices include shipping, taxes, and discounts when available
Generated by PCPartPicker 2017-04-22 08:45 BST+0100
Just been told by a mate that there a full sandy bridge in system for sale close to me for £400 too, and that's rocking a 1060 and o's.....so decisions need to be made
That seems over budget to me:p
To save money, you could get a 1400X. You get a CPU cooler with that which would mean you save some money by dropping the Hyper 212. Will have less overclocking headroom though
I'm from Denmark, so I don't know where you buy used stuff in UK :-) but being on a budget I would start out with used stuff. You can get a lot of performance per £
I'd make sure that your chosen memory is on your motherboard's QVL list, just to be sure that it will work. Below is link to the QVL list.
https://www.asus.com/uk/Motherboards/PRIME-B350-PLUS/HelpDesk_QVL/
I also recommend looking at the Overclockers UK clearance section, they have an RX 480 for £170 ATM and a few deals on 144Hz FreeSync panels. Could save you guys a few £ looking there. I would go for an RX 480 over an RX 570.
Any particular reason why you are going for the Deathadder Chroma mouse? Surely there are better mice available for this bang/buck build. I still use my £20 Cooler Master Xornet mouse after years of constant use with no issues, not that the Chroma is bad, just that the money could be better spent elsewhere.
Drop that Hyper 212 evo as you will get a cooler with it. Also I heard OCUK have some deals on GPU's ATM too. EDIT: WYP has already informed us of the OCUK deals :)
