GadgetGarrett
Gave it a whirl but I prefer the tubes at the top, each to their own![]()
I've got the tubes running from the top on my H80i
Nice build - keep us updated.
Actually if you trust the PSU and its of a high quality (not familiar with how good CM is for PSU's) you should be fine, even with 50w allowance for a spike youre still under 500w from the wall if you bought a 280x!
Not really sure if I do. Don't really fancy watching the PSU go bang and taking everything with it!
ThanksTubes seem much thicker and shorter on the H80i compared to H75. Nice looking rig you have there
Very clean! shame the psu can't be hidden as it bothers me (the cables don't match the extensions)
This just needs a PSU cover and it will look even cleaner!Barnsley! I hate extentions for that exact same reason!
Your PSU has 42A and puts out a healthy 504W on the 12V rail so running that R9 280X should be fine. That said it won't be any use if you ever decide to go crossfire, and it also suffers from very low efficiency at high loads, not to mention that it could easily suffer a blowout if too much load were to be placed on the 12V rail too quickly.
If you do decide to upgrade your GPU to something like the R9 280X or even an R9 290, I would personally suggest picking up a better PSU as well. That way you can be more certain of flawless performance in the short term, as well as leaving plenty of room for upgrades in the future.
^^this. However, your PSU isn't actually bad, iirc its 80+ bronze? a 280x would be about it before you went past a safe amount of load but up to there you should be fine.
The PSU isn't bad for now, but there would be big problems should the OP wish to upgrade anything else. If you are spending decent money on a GPU, then purchasing a PSU to match and allow for more upgrading later is always a good idea in my opinion. Otherwise it is a matter of false economy.
As to the load issue I mentioned, I was referring more to the inrush current issue. When the inrush was tested for this model of PSU there were found to be component quality issues that could easily contribute to things getting damaged. This was the basis for my statement regarding load issues, my apologies for not being clearer before.
For more information on inrush see this article http://www2.electronicproducts.com/...inrush_current-article-bear-mar2006-html.aspx and for more on the inrush issue with this PSU please go here: http://www.techpowerup.com/reviews/CoolerMaster/G550M/5.html and then the relevant part of the conclusion for that article found here: http://www.techpowerup.com/reviews/CoolerMaster/G550M/11.html
