Boot Issues
Permafrost
Compo Whore
hello guys and girls, i got this weird problem after the nvidia driver update (347.88)
i've one once had this issues and i did a driver sweep and it was gone.
so this time i did the same thing and this time the problem is still here (stubborn b*****d grrr)
i thought it would be best to put up a video
https://www.youtube.com/watch?v=t1fi1mf-pKw&feature=youtu.be
Specs
i7 4770k
sabertooth z87
gtx 780
hyper x beast 2400mhz
AX760
nzxt leds white
watercooling bit
ek xtx 360
ek xtx 240
xspc razor titan block and backplate
xspc raystorm
xspc fittings 10/16
xspc hose
DDC 3.2 18w pump
ek x-res 140
pump mounting thing?! (next time I'll just build my own.)
NF-F12 x 5
Hmm odd, Could be that the GPU isn't kicking in properly.
Best bet is to ask on the Nvidia forums as you might get an answer from a driver dev.
but your rig is a lot faster :)
i'm going to go over it again with driver sweeper and with a bit of luck it's work.
Not really a lot faster, My CPU is just the better thermal compound version of yours and the 980 is just the 780 Ti with better power usage/thermals ^_^
i still think people who went from a 780ti to a 980 for gaming wasted their money :P
also my card it a 780 just overclocked to the same level as a ti (i think)
right i did all that driver sweeping and still have the issue but boots fine in safe mode.
now i'm thinking it's windows :(
anyone had this issues?
Where is the sound output from? Motherboard or HDMI via GPU? If its the motherboard I almost wonder if its a windows issue from the recent patches.
it's from a 3.5mm jack to an onkyo amp.
no new patches i've tried a system restore nothing...
it's fine in safe mode, to that leads me to believe it's something to do with windows.
i've done a health check with HD tune and the ssd and hdd are ok.
Not had that issue for a long time, remove all recent driver updates and reinstall them, including Audio and Chipset drivers. By remove I mean with DDU followed by a fresh install, if it persists just roll back to a driver platform that worked.
yeah i tried all that dude :(
for some reason the problem is now gone..... for now but i still want to get to the bottom of this issue..
Sorry, didn't see you had replied.
I think it could be something to do with your GPU as I don't think that the audio chip from the GPU is used in safe mode. I'd disable all audio from your GPU.
i only have the audio coming from the mobo dude..
might look in to getting a sound card, but at the mo i'm saving up for a new case.
