darthgalactis
I was debating whether to hold off posting this build until I got a video card, but I decided against it. The integrated graphics runs Hearthstone exceptionally well and I've decided to wait until Maxwell (790 or 880). I currently have a pair of 5970's that I hope I can sell for a good price. Rumour has it that they are ideal cards for Bitcoin mining. But whether they sell or not, it will not deter me from buying one of these cards.
My last rig (X58) is 4 years old and is starting to show signs of slowing down, so I figured why not now?. After watching Tom's review of the H440 I instantly fell in love with the case. I also began dreaming up my next build and started putting it together in my imagination. I've always been nervous setting up a custom liquid cooling loop; however, the fear of damaging anything is what prevents me from even attempting it. My next build will be different as it seems I've finally overcome this fear. I've discovered that if you are not in a rush and take your time, any build can come out damn near perfect.
The only thing I thought was worth mentioning is that a 760AX will fit into the prodigy. But it's extremely tight fit and you will have to force it in there. All 4 of my SP120 QE's had noticeable clicking sounds, so I had to RMA2 to Corsair and return 2 to a local store. I don't know if I'm going insane but all SP120 QE's seem to have an extremely faint click/hum.
All things aside I really enjoyed putting this together, and i'm looking forward to the next one.
Cheers!
CPU: Intel Core i7-4770K 3.5GHz Quad-Core Processor
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler
Motherboard: MSI Z87I GAMING AC Mini ITX LGA1150 Motherboard
Memory: G.Skill Trident X Series 16GB (2 x 8Gb) DDR3-2400 Memory
Storage: Samsung 840 Pro Series 512GB 2.5" Solid State Disk
Case: BitFenix Prodigy (Red) Mini ITX Tower Case
Case Fan: Corsair Air Series SP120 Quiet Edition (2-Pack) 37.9 CFM 120mm Fans
Case Fan: Corsair Air Series AF140 Red 66.4 CFM 140mm Fan
Case Fan: BitFenix BFF-LPRO-23030R-RP 156.3 CFM 230mm Fan
Power Supply: Corsair 760W 80+ Platinum Certified Fully-Modular ATX Power Supply
Cables:
Cheers!
Cables:
Corsair Individually Sleeved AX 860/760 ATX 24pin (Generation 2), RED
Corsair Professional Individually sleeved DC Cable Kit, Type 3 (Generation 2), RED
BitFenix Prodigy Window Side Panel - Red
BitFenix Molex to 3 Fan Adapter 7V 20cm Red
BitFenix SATA Cable with Sleeve 30cm Red
