Some nice kit you got there, can't wait to see more
Oh no, don't start this again!
shit when did I do it before? my badz
I'm simply going to ignore that...Sorry for asking but were you actually born in 98? How can you have all that money at 14? or was it a parents job?
It will come soon... The build is done, so I could technically dump all of the pictures on you at once... But it's more suspenseful this way.Some nice kit you got there, can't wait to see more![]()
I do believe you haveHave I said MOARRRRRRRRR yet?
http://www.newegg.com/Product/Product.aspx?Item=N82E1682023323032GB Dominator GT :O Thats some expensive shit right there :L
Good choice on the graphics cards btwAnd the MX4
It's so thin!!!
Sorry to hear that bro*Sigh*... Couldn't help it...
Thats what she said...
...You sure it's the RAM that needs over volting and not the CPU memory controller?
RAM never needs watercooling unless you're seriously pushing the overclocks (which you aren't) and even then you'd have to be running 24/7 memtests for them to actually get too hot. 1.5 to 1.6v won't really do anything you'd need to worry about.
You'd be running the RAM at its rated specs - and not doing massive RAM intensive applications 24/7.
It will be fine.
Yeah its NOT the ram you just need to set the BIOS up right, 32GB of ram is not for beginners.......
Well, I want to keep the timings down a bit. It gets up to like 60c....You sure it's the RAM that needs over volting and not the CPU memory controller?
It will be fine.
Well, I don't know where to start, because so many people have told me so many different things.Yeah its NOT the ram you just need to set the BIOS up right, 32GB of ram is not for beginners.......
Well, they were stated at 1.5 volts when I bought them. So you mean they're supposed to be at 1.65?Both of this^^
1.65v is the rated spec for those sticks so no overvolting required.
If you want speed then you should of bought the Samsung ECO sticks instead of those.
Watercooling Ram is a bling thing and absolutely pointless....if it was DDR2,then you have a point but DDR3? No.
Umm... I am afraid of this badge. Why do I have a feeling it won't be nice.watercooling ram is for n00000bs.
Ill make you a special badge if you do it![]()
